328
Mar 30, 2024 6:34 am
Cause : Option fault comes when the inverter trips when a contact fault is found between the inverter and the plug-in option, or when the communication option is not connected to the connector 1.
Appears when the switch for manufacturer setting of the plug-in option is changed.
- Check that the plug-in option is plugged into the connector properly.
- Check for excessive noise around the inverter.
- Check if the communication option is connected to the connector 2 or 3.
- Connect the plug-in option securely.
- Connect the communication option to the connector 1.
