E.OC3 fault error code in Mitsubishi F800
Cause : Overcurrent trip during deceleration or stop comes when the inverter output current reaches or exceeds approximately 170% (LD rating) / 148% (SLD rating) of the rated current during deceleration (other than acceleration or constant speed), the protection circuit is activated and the inverter output is shutting off.
  1. Check for sudden speed reduction.
  2. Check for output short-circuit.
  3. Check for too fast operation of the motor's mechanical brake.
  4. Check if the stall prevention operation level is set too high. Check if the fast-response current limit operation is disabled.
  5. Check that the power supply for RS-485 terminal is not shorted (under vector control).
  6. Check that the rotation direction is not switched from forward to reverse rotation (or from reverse to forward) during torque control under Real sensorless vector control.
  7. Check that the inverter capacity matches with the motor capacity. (PM sensorless vector control)
  8. Check if a start command is given to the inverter while the motor is coasting. (PM sensorless vector control)
