rE1 fault error code in Mitsubishi F700
Cause : Parameter read error comes when a failure has occurred at the operation panel side EEPROM while reading the copied parameters.
  1. A failure has occurred in the USB memory device while copying the parameters or reading the PLC function project data.
  2. Perform parameter copy again.
  3. Perform PLC function project data copy again.
  4. The USB memory device may be faulty. Replace the USB memory device.
  5. The operation panel (FR-DU08) may be faulty.
