E018 fault error in commander S100 control techniques drive
Cause : Tune Interrupted comes when the drive was prevented from completing an auto-tune, because either the drive enable or the drive run signals were removed.
  1. Ensure the drive enable signal is active for the entire auto-tune. This can be checked using Sequencer Input and Output Indicators (P1.11).
  2. Ensure a run signal (Run Forward, Run Reverse or Run) is active for the entire auto-tune. This can be checked using Run & Direction Indicators (P1.12).
  3. If these signals are supplied by a digitl input, check the states of the IO using Digital IO Indicators (P1.25).
