E228 fault error in commander S100 control techniques drive
Cause : Ground fault comes when the drive has detected a ground (earth) fault on the motor cable/windings. A ground fault in a motor drive system occurs when an unintended connection is made between an electrical conductor and the ground (earth).
  1. Check for short circuit to ground (earth) on the output cables.
  2. Check the integrity of the motor insulation using an insulation tester
