Nidec & Control Techniques Commander S, SE, SX, SK & SP Drive
1,504
Apr 06, 2024 4:42 am
Cause : Output current overload timed out (I 2 t) - accumulator value can be seen in Pr 4.19. Ensure the load is not jammed / sticking.
- Ensure that the motor rated current is not set to zero.
- Check the load on the motor has not changed.
- Ensure rated speed parameter is correct (RFC).
- Tune the rated speed parameter (closed loop vector only).
