OI.br fault in unidrive SP nidec control techniques drive
Cause : Braking transistor over-current detected- short circuit protection for the braking transistor activated comes when there is an unintended connection between two conductors, resulting in a sudden increase in current flow, potentially damaging the drive or connected equipment.
  1. Check braking resistor wiring.
  2. Check braking resistor value is greater than or equal to the minimum resistance value.
  3. Check braking resistor insulation.
