Nidec & Control Techniques Unidrive M700, M600, M400, HS30 & HS70 Drive
486
Apr 12, 2024 11:40 am
Cause : Autotune test stopped before completion comes when the drive was prevented from completing an autotune test, because either the drive enable or the drive run were removed.
- Check the drive enable signal (terminal 31 on Unidrive M700 / M701 and terminal 11 & 13 on Unidrive M702) was active during the autotune.
- Check the run command was active in Pr 08.005 during autotune.
