Derivative Image fault in nidec control techniques drive
Cause : Derivative Image error comes when the Derivative Image trip indicates that an error has been detected in the derivative image. The sub-trip number indicates the reason for the trip.
Sub-trip & Reason given below:
1 to 52 An error has been detected in the derivative image.
61 The option module fitted in slot 1 is not allowed with the derivative image.
62 The option module fitted in slot 2 is not allowed with the derivative image.
63 The option module fitted in slot 3 is not allowed with the derivative image.
64 The option module fitted in slot 4 is not allowed with the derivative image.
70 An option module that is required by the derivative image is not fitted in any slot.
71 An option module specifically required to be fitted in slot 1 not present.
72 An option module specifically required to be fitted in slot 2 not present.
73 An option module specifically required to be fitted in slot 3 not present.
74 An option module specifically required to be fitted in slot 4 not present.
