Nidec & Control Techniques Unidrive M700, M600, M400, HS30 & HS70 Drive
387
Apr 13, 2024 4:52 am
Cause : Multi-Power module drive interconnection cable error comes when the Inter-connect trip indicates a multi-power module drive interconnection cable error.
- The sub-trip "xx.0.00" indicates which power module has detected the fault where xx is the power module number.
- It should be noted that this trip is also initiated if the communication fails either when a rectifier signals a fault or a trip is reset.
- In this case, the sub-trip is the number of modules that are still communicating correctly.
