Nidec & Control Techniques Unidrive M700, M600, M400, HS30 & HS70 Drive
677
Apr 13, 2024 5:44 am
Cause : Ethernet interface in slot 4 has changed comes when the Slot4 Different trip indicates that the Ethernet interface in slot 4 has changed / not found.
- Turn off the power, ensure that the correct option module is installed in the option slot and re-apply the power.
- Confirm that the currently installed option module is correct, ensure the option module parameters are set correctly and perform a User Save in Pr mm.000.
