Nidec & Control Techniques Unidrive M700, M600, M400, HS30 & HS70 Drive
294
Apr 13, 2024 5:48 am
Cause : Option module in option slot X has changed comes when the SlotX Different trip indicates that the option module in option slot X on the drive is a different type to that installed when parameters were last saved on the drive.
- Turn off the power, ensure the correct option modules are installed in the correct option slots and re-apply the power.
- Confirm that the currently installed option module is correct, ensure option module parameters are set correctly and perform a user save in Pr mm.000.
