BRAKE RESISTOR fault in parker AC690 drive
Cause : BRAKE RESISTOR comes when a problem with the brake resistor, a component used to dissipate energy during braking. This fault can prevent the drive from stopping or decelerating properly.
BRAKE RESISTOR fault in Parker AC690 drive indicates that the brake resistor has been subjected to a load that exceeds its designed capacity, leading to potential overheating and damage. Brake resistors are used to absorb and dissipate excess energy during braking; if they are overloaded, it can cause performance issues or failures in the braking system.
  1. Excessive Braking Energy:
    • Cause: The amount of energy being absorbed by the brake resistor may exceed its rated capacity, often due to frequent or high-energy braking.
    • Solution:
      • Check braking conditions: Review the application to determine if the braking energy is consistently high. If necessary, reduce the braking energy by adjusting acceleration and deceleration profiles.
      • Upgrade the resistor: Use a brake resistor with a higher power rating to handle the excess energy. Ensure it is properly sized for the application’s requirements.
  2. Incorrect Brake Resistor Rating:
    • Cause: The brake resistor may not be rated appropriately for the drive or application, leading to frequent overload conditions.
    • Solution:
      • Verify resistor specifications: Ensure that the brake resistor is correctly rated for the drive and application. Consult the drive’s manual or specifications to select a resistor with the appropriate power rating.
  3. Insufficient Cooling:
    • Cause: Inadequate cooling or ventilation around the brake resistor can cause it to overheat and trigger an overload fault.
    • Solution:
      • Improve ventilation: Ensure that there is sufficient airflow around the brake resistor. Check for any obstructions or blockages in the ventilation system.
      • Inspect cooling fans: If the resistor has associated cooling fans, ensure they are functioning properly and replace any that are faulty.
  4. Extended Braking Periods:
    • Cause: Prolonged or frequent braking can lead to overheating if the brake resistor is not able to dissipate the heat quickly enough.
    • Solution:
      • Adjust braking profiles: Modify the drive’s braking settings to reduce the frequency and duration of braking events. Implement a strategy to distribute braking energy more evenly.
  5. Faulty Brake Resistor:
    • Cause: The brake resistor itself may be defective or damaged, leading to overheating and overload conditions.
    • Solution:
      • Inspect and test the resistor: Check the brake resistor for signs of damage or wear. Replace the resistor if it is found to be faulty.
