CONTACTOR FEEDBACK fault in parker AC690 drive
Cause : CONTACTOR FEEDBACK comes when DC Link failed to reach the undervoltage trip level within the contactor feedback time.
CONTACTOR FEEDBACK fault in parker AC690 drive indicates a problem with the line contactor, a device used to control the power supply to the drive. This fault can prevent the drive from starting or operating correctly.
Common Causes of CONTACTOR FEEDBACK Faults:
  • Contamination: Dirt, debris, or foreign objects can accumulate on the line contactor's contacts, preventing them from closing properly.
  • Wear and Tear: Over time, the line contactor's contacts can wear out or become damaged, affecting their ability to conduct electricity.
  • Electrical Issues: A short circuit or open circuit in the line contactor or its associated circuitry can cause the fault.
  • Drive Internal Issues: Faulty components within the drive itself can contribute to line contactor problems.
  1. Inspect the Line Contactor:
    • Visually inspect the line contactor for any signs of damage, corrosion, or contamination.
    • Check the contacts for wear or pitting.
  2. Test the Line Contactor:
    • Use a multimeter to test the continuity of the line contactor's contacts. The contacts should conduct when the line contactor is closed and have no continuity when it is open.
  3. Check Electrical Connections:
    • Inspect the wiring associated with the line contactor for any signs of damage, corrosion, or loose connections.
    • Ensure that the line contactor is properly connected to the drive's power supply.
Click2Electro
Get free chat support...
🟢 Online
