Incompatible stack fault in parker AC30 drive
INCOMPATIBLE STACK fault in Parker AC30 drive indicates a mismatch between the drive's power stack and the motor or other connected components. This can prevent the drive from operating correctly or can lead to performance issues.
Common Causes of INCOMPATIBLE POWER STACK Faults:
  • Incorrect Motor Selection: The motor may not be compatible with the drive's power stack in terms of voltage, current rating, or other specifications.
  • Power Stack Damage: The power stack itself may be damaged or faulty.
  • Drive Configuration Errors: Incorrect settings or parameters on the drive can cause a mismatch between the power stack and the connected components.
  1. Verify Motor Compatibility:
    • Ensure that the motor is compatible with the drive's power stack in terms of voltage, current rating, and other specifications.
    • Refer to the drive's manual and the motor's specifications for more information.
  2. Inspect Power Stack:
    • If possible, visually inspect the power stack for any signs of damage or discoloration.
    • Note that this may require disassembling the drive, which should only be done by qualified technicians.
  3. Check Drive Configuration:
    • Verify that the drive's configuration settings are correct for the connected motor.
    • Ensure that the drive is set to the correct motor type and operating mode.
