INTERNAL FAN FAIL fault in parker AC30 drive
Cause : INTERNAL FAN FAIL comes when an internal cooling fan has failed. This will reduce the lifetime of the power electronics.
INTERNAL FAN FAIL fault in a Parker AC30 drive indicates a failure of the internal cooling fan. This can lead to overheating of the drive's components, potentially causing damage or reduced performance.
Common Causes of INTERNAL FAN FAIL Faults:
  • Mechanical Failure: The fan motor or bearings may have failed.
  • Blocked Airflow: Dust, debris, or other obstructions can prevent the fan from operating effectively.
  • Electrical Issues: A short circuit or open circuit in the fan's wiring or control circuitry can cause it to fail.
  • Drive Internal Issues: Faulty components within the drive itself can contribute to fan failures.
  1. Inspect the Fan:
    • Visually inspect the fan for any signs of damage, wear, or obstructions.
    • Check if the fan blades are rotating.
  2. Check for Blocked Airflow:
    • Ensure that there are no obstructions blocking the airflow to or from the fan.
    • Clean the fan and its surrounding area to remove any dust or debris.
  3. Test the Fan:
    • If possible, use a multimeter to measure the voltage and current supplied to the fan.
    • If the fan is receiving power but not rotating, it may be faulty.
