KE TOO LARGE fault in parker AC30 drive
KE TOO LARGE fault in parker AC30 drive - Ke value calculated during the autotune (stationary) is too large (the max value is 840V)
  1. Check the motor data is correct, especially nameplate rpm, rated amps and motor volts.
  2. If low speed motor with a Ke value higher than 840V, enter by hand the corresponding value after the autotune completion.
