480
Sep 10, 2024 6:05 am
Cause : MOTOR TURNING ERROR comes when the motor must be stationary when starting the Autotune. This could be due to a variety of factors, such as mechanical issues, electrical problems, or software errors.
MOTOR TURNING ERROR fault in parker AC690 drive indicates a problem with the motor's ability to rotate or maintain a specific speed.
Mechanical Issues:
- Solution: Inspect the motor for any physical damage, such as broken shafts, worn bearings, or binding. Check for obstructions that might be preventing the motor from turning.
- Consider: Performing a thorough mechanical inspection and addressing any identified problems.
Electrical Issues:
- Solution: Check the motor's electrical connections for any loose, damaged, or shorted wires. Ensure that the motor is receiving the correct voltage and current.
- Consider: Using a multimeter to measure the motor's current draw and voltage supply.
Software Issues:
- Solution: Verify that the drive's software settings are appropriate for the motor and load. Incorrect settings, such as a misconfigured motor type or an inappropriate starting method, can cause the motor to fail to turn.
- Consider: Consulting the drive's manual for proper settings and troubleshooting guidelines.
External Factors:
- Solution: Check for any external factors that might be affecting the motor's ability to turn, such as excessive load, mechanical jamming, or environmental conditions.
