361
Sep 10, 2024 5:09 am
Cause : OVER CURRENT comes when the drive is drawing more current than its rated capacity. This can be caused by various factors, including overloading, short circuits, or internal drive issues.
Overcurrent fault in Parker AC690 drive indicate that the current flowing through the drive exceeds its rated capacity. This can be caused by several factors, including issues with the motor, wiring, load, or even drive settings.
Common Causes of OVER CURRENT Faults:
- Overloading: Attempting to drive a load that exceeds the drive's rated power capacity can lead to excessive current draw.
- Short Circuit: A short circuit between motor phases or between a phase and ground can cause a sudden surge of current, triggering the fault.
- Motor Problems: Faulty motor windings, bearings, or other mechanical issues can increase the current draw and lead to an overcurrent fault.
- Drive Internal Issues: Internal components within the drive, such as transistors or capacitors, may fail and cause excessive current flow.
- Verify Load:
- Ensure that the load connected to the drive does not exceed its rated power capacity.
- If necessary, reduce the load or use a drive with a higher power rating.
- Check for Short Circuits:
- Inspect the motor wiring for any signs of damage or insulation breakdown.
- Verify that there are no short circuits between motor phases or between a phase and ground.
- Inspect the Motor:
- Check the motor for any signs of overheating, bearing noise, or other mechanical problems.
- If necessary, replace the motor with a new one.
- Inspect the Drive:
- Look for any visible damage or signs of overheating on the drive's exterior.
- Check for loose connections or faulty components.
- Reset the Drive:
- If the fault persists, try resetting the drive to its default settings. This may resolve temporary issues caused by software glitches.
