Parker AC890 drive Alert Messages
Explanation of common alert messages on Parker AC890 series AC drives, their potential causes, and recommended actions to prevent them from escalating into faults. Improve drive performance and reliability by understanding these warnings.
Below list shows Parker AC890 drive Alert Messages :
Alert Message IDs
ID
Message
Reason
6901 Keypad
6511 Keypad
No Alert
RUNTIME ALERT
XXXX               YYYYYYYY
XXXX
Runtime alert
2
SAVING
SAVE
Saving to flash
3
LOADING
LOAD
Loading from flash.
4
LIMIT REACHED
HI
High or low limit reached while editing.
5
KEY INACTIVE RUN FORWARD TRUE
RUN
Can’t switch to remote mode.
6
KEY INACTIVE RUN REV TRUE
RUN
7
KEY INACTIVE JOG TRUE
JOG
8
KEY INACTIVE REMOTE SEQ
SEQ
Run, Jog and direction keys inactive.
9
KEY INACTIVE REMOTE REF
REF
Direction key inactive.
10
KEY INACTIVE DRIVE RUNNING
RUN
Local/Remote and Jog keys inactive.
11
KEY INACTIVE COAST STOP FALSE
STOP
Run and Jog keys over ridden.
12
KEY INACTIVE FAST STOP FALSE
STOP
13
KEY INACTIVE ENABLE FALSE
ENBL
14
CONFIG MODE FAILED
ERR1
Unable to enter configuration mode.
15
KEY INACTIVE READ ONLY
READ
Can’t edit read-only parameters
18
CHECKSUM FAIL DEFAULTS LOADED
ERR2
Error reading data on power-up.
19
SUCCESS
GOOD
20
FAILED
FAIL
21
NEW PCODE FAILED
FAIL
Failed to save new product code or country data.
22
DEFAULTS LOADED
DATA
Loaded default fixed parameters.
23
KEY INACTIVE NO FREE LINKS
ERR3
Obsolete message
24
KEY INACTIVE LOCKED
ERR4
Obsolete message
25
QUADRATIC TORQUE UP TO CONFIRM
ND
Validate change to quadratic torque mode.
26
CONSTANT TORQUE UP TO CONFIRM
HD
Validate change to constant torque mode.
27
USING BACKUP APPLICATION
ERR5
Failed to load most recently save application, using previous copy. This applies to:
Fixed parameter file, (APP.CFG)
Fixed motor data file, (MOTOR1.MOT) Fixed persistent data file, (APP.PST) Default frequency and language file, (COUNTRY.SYS)
Drive ID file, (DRIVE_ID.SYS), now obsolete.
28
NEW PCODE SUCCESS
CODE
Saved new product code.
29
CONFIG MODE LOCKED
CONF
Exiting configuration mode.
30
FILE SYSTEM CORRUPT
FILE
The file store is corrupted. All saved files are lost.
31
USING BACKUP POWER DATA
CODE
At least one copy of the stack eeprom data has been corrupted.
32
POWER DATA CORRUPT
CODE
All copies of the stack eeprom data have been corrupted.
33
NEW POWER DATA DEFAULTS LOADED
CODE
Power board data on the control board does not match that on the stack eeprom.
34
LANGUAGE DEFAULTS LOADED
LANG
Default language and frequency settings lost.
35
USING BACKUP LANGUAGE
LANG
Obsolete message
36
APPLICATION NOT FOUND
DATA
Attempt to save fixed parameter set before it is valid.
37
AUTOTUNE IN PROGRESS
ATN
38
OPERATOR
OPER
Alert displayed while changing to the operator menu on pressing the PROG key.
39
DIAGNOSTIC
DIAG
Alert displayed while changing to the diagnostic menu on pressing the PROG key.
40
QUICK SETUP
SET
Alert displayed while changing to the quick setup menu on pressing the PROG key.
41
SETUP
PAR
Alert displayed while changing to the setup menu on pressing the PROG key.
42
SYSTEM
SYS
Alert displayed while changing to the system menu on pressing the PROG key.
43
SUPER USER TRUE
SUPR
Reserved for Parker Hannifin Manufacturing.
44
INCOMPATIBLE POWER BOARD
ERR6
Power board 500v and/or underlap signals incompatible with selected product code.
45
CALIBRATION CHECKSUM FAIL
CAL
The control board calibration data is invalid.
46
INCOMPATIBLE PCB
PCB
Software is not compatible with this version of control card PCB.
47
INCOMPATIBLE POWER BOARD TYPE
TYPE
Stack has been marked as a 650 or Baldor stack
48
INCOMPATIBLE EEPROM FLAGS
FLGS
Reserved flags in stack eeprom are not zero. See comms command ri.
49
INCOMPATIBLE POWER BOARD CODE
CODE
Product code not compatible with this version of software.
50
KEY INACTIVE
PRE
Alert shown when the RUN key is pressed when the Pre-charge relay is still open. This implies that the DC Link voltage is below the under-voltage trip level.
51
INCOMPATIBLE STO TEST RECORD
STO
The internal record confirming that the STO feature is tested has become corrupted.
52
LOCKED STO TEST RECORD
STO
The control card is incompatible with the power stack STO feature.
