Unimplemented Function fault in parker AC30 drive
UNIMPLEMENTED FUNCTION fault in Parker AC30 drive indicates that a specific function or feature is not supported by the drive's firmware or hardware. This can occur when trying to access a feature that is only available in higher-end models or with additional software options.
Common Causes of UNIMPLEMENTED FUNCTION Faults:
  • Feature Limitations: The drive's firmware or hardware may not support the specific function you are trying to access.
  • Incorrect Configuration: The drive's configuration settings may not be compatible with the desired function.
  • Software Compatibility Issues: The software or application you are using to control the drive may not be fully compatible with the drive's capabilities.
  1. Verify Functionality:
    • Check the drive's manual or specifications to confirm if the desired function is supported.
    • If the function is supported, ensure that the drive's firmware is up-to-date.
  2. Review Configuration Settings:
    • Verify that the drive's configuration settings are correct for the desired function.
    • Refer to the drive's manual for specific instructions on configuring the function.
  3. Check Software Compatibility:
    • Ensure that the software or application you are using is compatible with the drive's capabilities.
    • Check for any software updates or patches that may address compatibility issues.
