VOLT VOLTS SELECTION fault in Parker AC890 drive
Cause: VOLTS SELECTION comes when invalid position on volts selector switch. This typically occurs when the drive detects a mismatch between its internal voltage configuration and the actual incoming line voltage.
VOLT VOLTS SELECTION fault in Parker AC890 drive indicates that there is an inconsistency or an invalid setting related to the drive's voltage selection or its configured input voltage range.
