PLCs, Controller & DCS
934
Jun 24, 2024 11:44 am
Configuring a HART sensor in Siemens TIA Portal involves setting up both the HART module and the HART communication itself. Here's a general breakdown:
- Configuring the HART Module:
- Open TIA Portal and create a project.
- Add a compatible CPU and the HART module.
- In the Device View, navigate to the HART module and open its properties.
- Enable diagnostics and set measurement parameters for the channel connected to the HART sensor.
- Enable the HART function for that channel.
- Configuring HART Communication:
- Navigate to "HART variables settings" within the HART module properties.
- This might involve using SIMATIC PDM, a separate tool included with TIA Portal.
- Consult the specific HART sensor's manual to identify the desired process variables.
- Within the HART configuration, choose the relevant process variables to be read from the sensor.
