How to do Upload and Online edit in RSLogix 5000?
Uploading and online editing in RSLogix 5000 (now known as Studio 5000 Logix Designer) allow you to retrieve the existing program from a PLC and make changes to it while the PLC remains in operation. Here are the steps to upload and perform online editing in RSLogix 5000:
Uploading the Program:
  1. Connect to the PLC: Ensure that you are connected to the PLC through the appropriate communication interface (such as Ethernet/IP, USB, or serial).
  2. Open RSLogix 5000: Launch the RSLogix 5000 software and open the project associated with the target PLC.
  3. Select Controller Organizer: In the project window, navigate to the Controller Organizer pane on the left side.
  4. Connect to the PLC: Right-click on the controller (CPU) that represents the PLC you want to upload from. Select "Go Online" from the context menu to establish a connection to the PLC.
  5. Upload the Program: Once online, right-click on the controller again and select "Upload Program" from the context menu. Choose the desired upload method (e.g., Upload All or Upload Selected) and follow the prompts to retrieve the program from the PLC.
Online Editing:
  1. Online Mode: After uploading the program, the controller will be in online mode, allowing you to monitor its operation and make changes while it continues to run.
  2. Navigate to Program: In the Controller Organizer, expand the "Programs" folder under the controller. Double-click on the program you want to edit to open it.
  3. Edit Program: Once the program is open, you can make changes to ladder logic, function block diagrams, structured text, etc., as needed. You can add, delete, or modify rungs and instructions.
  4. Download Changes: After making your edits, you can download the changes to the PLC by clicking the "Download" button in the toolbar or selecting "Download" from the "Communication" menu. Follow the prompts to download the modified program to the PLC.
  5. Monitor Operation: While downloading changes, the PLC will enter Program mode, and the program will be halted momentarily. After the download is complete, the PLC will return to Run mode, and the modified program will start executing.
  6. Testing: After downloading changes, it's essential to thoroughly test the modified program to ensure it functions as expected and does not introduce any unintended consequences.
  7. Save Changes: Once you're satisfied with the modifications, save your project to preserve the changes made to the program.
By following these steps, you can upload an existing program from a PLC and perform online editing in RSLogix 5000 to make modifications while the PLC remains operational.
