Kinetix 5100 Micro 850 "E" Implicit Messaging
The Micro 850 "E" with implicit messaging is designed to simplify communication between the controller and Kinetix 5100 servo drives from Rockwell Automation. Here's a breakdown of the key points:
What it is:
  • Implicit messaging is a communication method where the PLC (Micro 850 "E" in this case) automatically manages data exchange with the drive (Kinetix 5100) without requiring explicit instructions for each data point.
  • This simplifies programming compared to traditional explicit messaging where you define every data transfer.
Benefits:
  • Reduced programming time: Pre-defined tags and function blocks streamline communication setup.
  • Easier development: The intuitive interface allows for faster development of control logic.
  • Improved performance: Optimized communication reduces processing overhead on the controller.
Requirements:
  • Micro 850 "E" Controller: Look for models with "E" in the part number (e.g., 2080-L50E). These models have built-in implicit messaging capabilities.
  • Firmware Version: The controller firmware needs to be version 21.011 or later.
  • Software: You'll need Connected Components Workbench software version 21 or later to program the Micro 850 "E" and configure implicit messaging.
Kinetix 5100 Drive: The Kinetix 5100 drive itself is compatible with implicit messaging.
