KV5500 Modbus-RTU RS485
The Keyence KV-5500 PLC supports RS485 communication, allowing it to communicate with other devices or PLCs using the RS485 serial communication protocol. Here's how you can set up RS485 communication with the KV-5500 PLC:
Terminal Details & Software :
S/R-  : Positive
S/R+ : Negative
Software : KV-Studio software
  1. Hardware Configuration:
    • Connect the RS485 communication module to the KV-5500 PLC. Ensure that the module is securely attached and properly wired according to the manufacturer's instructions.
  2. Termination Resistors:
    • In RS485 communication, it's essential to terminate the communication line properly to minimize signal reflections and ensure reliable communication. Ensure that termination resistors are installed at both ends of the RS485 communication line.
  3. Communication Parameters:
    • Configure the communication parameters such as baud rate, data format, parity, and node address on both the KV-5500 PLC and the devices it will communicate with. These parameters must match between the communicating devices for successful communication.
  4. Programming:
    • Write a control program for the KV-5500 PLC to implement the desired communication protocol and exchange data with other devices over the RS485 network.
    • Use the programming software provided by Keyence to create and debug the control program. Ensure that appropriate instructions for RS485 communication are included in the program.
  5. Addressing:
    • Assign a unique node address to each device on the RS485 network, including the KV-5500 PLC and any connected devices. This allows the PLC to identify and communicate with each device on the network.
  6. Testing and Debugging:
    • Test the RS485 communication between the KV-5500 PLC and other devices on the network to ensure proper functionality.
    • Use diagnostic tools provided by Keyence or third-party monitoring software to monitor the communication status and troubleshoot any communication issues.
  7. Integration:
    • Integrate the KV-5500 PLC into your industrial automation system, ensuring compatibility and interoperability with other PLCs, HMIs, and control devices on the RS485 network.
    • Verify that the PLC can exchange data with other devices and perform the desired control tasks over the RS485 network.
By following these steps, you can successfully set up RS485 communication with the Keyence KV-5500 PLC, enabling seamless integration into your industrial automation system for data exchange and control applications.
