Ladder Diagram Symbols: A Comprehensive Guide
Certainly! Let’s explore the essential ladder diagram symbols used in industrial control systems. These symbols play a crucial role in creating ladder diagrams, a graphical programming language widely used for automation and control. Understanding these symbols is key to designing effective ladder logic programs.
"Ladder diagram symbols" represent various components and operations in a control system. Each symbol corresponds to a specific instruction, similar to a secret code. Let’s delve into the most common ladder logic symbols:
1. Contact Symbols:
  • Normally Open (NO) Contact:
    • Represents an input or condition that must be true for the logic to proceed.
    • Symbol: !NO Contact
  • Normally Closed (NC) Contact:
    • Represents an input or condition that must be false for the logic to proceed.
    • Symbol: !NC Contact
  • Positive Transition-Sensing Contact:
    • Detects a rising edge (positive transition) in the input signal.
    • Symbol: !Positive Transition-Sensing Contact
  • Negative Transition-Sensing Contact:
    • Detects a falling edge (negative transition) in the input signal.
    • Symbol: !Negative Transition-Sensing Contact
2. Coil Symbols:
  • Coil (Output):
    • Represents an output device (e.g., motor, solenoid, relay).
    • Symbol: !Coil
  • Negated Coil (NOT Coil):
    • Represents the negation of an output.
    • Symbol: !Negated Coil
  • SET Latch Coil:
    • Sets an output to ON (latched).
    • Symbol: !SET Latch Coil
  • RESET Latch Coil:
    • Resets an output to OFF (unlatched).
    • Symbol: !RESET Latch Coil
3. Variations and Standards:
  • While IEC standards regularize ladder logic symbols, variations exist based on PLC programming software.
  • Some brands use different names (e.g., SET/RESET vs. LATCH/UNLATCH).
  • The symbols remain similar, with minor differences.
