Master control relay (MCR) in Ladder logic
In ladder logic programming, a Master Control Relay (MCR) is a special relay used to control the execution of multiple rungs or sections of a ladder diagram. It allows for the enabling or disabling of specific sections of the program based on certain conditions. The MCR typically consists of a normally open contact (M) and a coil (M). Here's how the MCR is used in ladder logic:
  1. MCR Coil (M):
    • The MCR coil (M) is typically placed at the beginning of the ladder diagram or in a central location.
    • When the MCR coil is energized, it enables the associated logic rungs or sections of the ladder diagram for execution.
    • When the MCR coil is de-energized, it disables the associated logic rungs, preventing their execution.
  2. MCR Contact (M):
    • The MCR contact (M) is placed on rungs where its status determines whether the associated logic is executed.
    • When the MCR coil is energized (M is closed), the MCR contact allows the associated logic to be executed.
    • When the MCR coil is de-energized (M is open), the MCR contact prevents the associated logic from being executed.
  3. Example Application:
    • Imagine a control system where certain safety conditions must be met before allowing the operation of a motor. The MCR can be used to control the enabling and disabling of the motor control logic.
    • The MCR coil could be energized by a start button or by meeting certain safety conditions (e.g., guards closed, emergency stop released).
    • The MCR contact could be placed on rungs containing the logic for starting and stopping the motor. When the MCR coil is energized, the motor control logic is enabled, allowing the motor to start or stop based on other input conditions.
  4. Advantages:
    • Using an MCR in ladder logic provides a centralized control point for enabling or disabling sections of the program.
    • It simplifies the programming by reducing the need for multiple enable/disable conditions scattered throughout the ladder diagram.
    • It improves the clarity and readability of the ladder logic program by clearly indicating which sections are controlled by the MCR.
In summary, the Master Control Relay (MCR) in ladder logic programming is a useful tool for controlling the execution of specific sections of a ladder diagram based on certain conditions, providing centralized control and improving the clarity of the program.
