PLC Programming :Introduction to Statement list
Statement List (STL) is a programming language used for programming Siemens PLCs (Programmable Logic Controllers). It is one of the five languages supported by Siemens Step 7 programming software, along with Ladder Logic (LAD), Function Block Diagram (FBD), Structured Text (ST), and Sequential Function Chart (SFC). STL is a low-level language that closely resembles assembly language and is primarily used for advanced programming and fine-tuning of PLC applications.
Here's an introduction to Statement List programming in Siemens PLCs:
  1. Syntax and Structure:
    • STL programs consist of a series of instructions, each represented by a mnemonic followed by operands and parameters.
    • Instructions are written in a linear fashion, with each instruction occupying a separate line.
    • The syntax of STL is similar to assembly language, with mnemonics representing specific operations or functions performed by the PLC.
  2. Data Types:
    • STL supports various data types, including BOOL (Boolean), BYTE (8-bit integer), WORD (16-bit integer), DWORD (32-bit integer), and others.
    • Data types are specified when declaring variables or operands in the program.
  3. Instructions:
    • STL instructions perform specific actions or operations on data within the PLC.
    • Common instructions include logical operations (AND, OR, XOR), arithmetic operations (ADD, SUB, MUL, DIV), comparison operations (CMP), bit manipulation (SET, RESET), and control flow instructions (JMP, CALL, RET).
  4. Addressing Modes:
    • STL uses different addressing modes to access data within the PLC memory.
    • Direct addressing mode specifies the memory location directly by its address.
    • Indirect addressing mode uses pointers or indexes to access memory locations dynamically.
    • Indexed addressing mode allows iterating through arrays or blocks of memory.
  5. Program Flow Control:
    • STL programs control the flow of execution using branching and looping instructions.
    • Conditional branching instructions (e.g., JMP, JC, JNC) transfer control to different parts of the program based on specified conditions.
    • Looping instructions (e.g., LOOP, END_LOOP) enable repetitive execution of a block of code.
  6. Subroutines and Functions:
    • STL allows organizing code into subroutines or functions for modular programming and code reuse.
    • Subroutines are defined using the CALL and RET instructions, allowing execution to jump to a specified subroutine and return after completion.
  7. Debugging and Testing:
    • STL programs can be debugged using simulation tools provided by the programming software.
    • Online monitoring and diagnostic features allow observing the behavior of the program in real-time and troubleshooting any issues.
  8. Performance and Optimization:
    • STL is a low-level language that offers precise control over PLC execution, making it suitable for optimizing performance and efficiency in critical applications.
    • Careful programming and optimization techniques can improve program execution speed and minimize resource usage.
Overall, Statement List (STL) programming provides a powerful and flexible approach to PLC programming, offering fine-grained control and high-performance execution in Siemens PLCs. While it may have a steeper learning curve compared to other programming languages, mastering STL can enable advanced control and customization of industrial automation applications.
