STEP 7 has found a problem with Automation Licence Manager
If you encounter an issue with the Automation License Manager in Siemens' STEP 7 software, it could be due to various reasons such as license activation problems, corrupted license files, or issues with the license server. Here are some steps you can take to troubleshoot the problem:
  1. Check License Activation: Ensure that your license for STEP 7 software is activated correctly. If you're using a floating license, make sure that the license server is running and accessible.
  2. Restart Automation License Manager: Try restarting the Automation License Manager service or application. Sometimes, a simple restart can resolve temporary issues.
  3. Check License Server Connection: If you're using a floating license, verify that the license server is reachable from your computer. Check network connectivity and firewall settings to ensure that there are no restrictions blocking communication with the license server.
  4. Reinstall License Files: If the license files are corrupted or missing, try reinstalling them. You may need to contact Siemens support or your license administrator to obtain valid license files.
  5. Update Software: Ensure that you're using the latest version of the STEP 7 software. Sometimes, updating to the latest version can resolve compatibility issues and software bugs.
  6. Check System Requirements: Make sure that your computer meets the minimum system requirements for running the STEP 7 software. Inadequate system resources can sometimes cause software issues.
  7. Contact Siemens Support: If you're unable to resolve the issue on your own, consider reaching out to Siemens technical support for assistance. They can provide further guidance and troubleshooting steps tailored to your specific situation.
By following these steps, you should be able to troubleshoot and resolve the problem with the Automation License Manager in Siemens' STEP 7 software.
