Weintek MT8071iE Modbus RTU RS485 Connection
To establish Modbus RTU RS485 communication with the Weintek MT8071iE HMI (Human-Machine Interface), then follow these steps :
Terminal details & pin configuration - use COM3 9 Pin, Female, D-sub
Pin details for RS485 : 6 (data -) and 9 (data +)
Software for HMI : EasyBuilder Pro
  1. Weintek MT8071iE HMI: This is the HMI device you're connecting to.
  2. RS485 Communication Port: The Weintek MT8071iE HMI has an RS485 communication port that supports Modbus RTU protocol. Ensure that the RS485 port is available and enabled on the HMI.
  3. Modbus RTU Slave Device: This could be a PLC, sensor, or any other Modbus RTU-compatible device that you want to communicate with.
  4. RS485 Cable: You'll need an RS485 cable to physically connect the HMI to the Modbus RTU slave device. This cable typically has two or three wires, depending on whether you need a half-duplex or full-duplex connection.
