What is Data Acquisition System?
A Data Acquisition System (DAQ), also known as Data Acquisition (DAQ) or Data Logger System, is a collection of hardware and software components used to acquire, monitor, record, and analyze analog and digital signals from various sensors, instruments, and devices. The primary purpose of a DAQ system is to measure and process real-world physical phenomena or signals and convert them into digital data for analysis, visualization, and storage. Here are the key components and functions of a typical Data Acquisition System:
  1. Sensors and Measurement Devices:
    • Sensors: These are transducers that convert physical parameters such as temperature, pressure, flow, voltage, current, strain, acceleration, position, or light intensity into electrical signals.
    • Measurement Devices: These include instruments such as voltmeters, ammeters, thermometers, pressure gauges, accelerometers, strain gauges, and others that provide analog or digital output signals corresponding to measured quantities.
  2. Signal Conditioning:
    • Signal Conditioning Circuitry: This involves preprocessing the raw signals from sensors and measurement devices to filter noise, amplify weak signals, scale voltage or current levels, linearize non-linear responses, and provide suitable impedance matching for optimal signal acquisition.
    • Signal Conditioning Modules: These can include amplifiers, filters, attenuators, voltage regulators, isolation amplifiers, analog-to-digital converters (ADCs), and digital-to-analog converters (DACs) tailored to specific sensor types and signal conditioning requirements.
  3. Data Acquisition Hardware:
    • Analog Input Modules: These modules digitize analog signals from sensors and measurement devices using ADCs and transmit the digital data to a computer or data acquisition unit for processing.
    • Digital Input/Output Modules: These modules interface with digital sensors, switches, relays, and control devices to acquire or generate digital signals for monitoring and control applications.
    • Multifunction DAQ Devices: These combine analog input/output channels, digital input/output channels, and other functionalities such as counters, timers, and signal processing capabilities in a single integrated unit.
  4. Data Acquisition Software:
    • User Interface: The software provides a user-friendly interface for configuring DAQ hardware settings, selecting input channels, setting acquisition parameters (sampling rate, resolution), and visualizing acquired data in real-time.
    • Data Logging and Storage: The software enables continuous or triggered data acquisition, recording acquired data in files or databases, and storing metadata such as timestamps, sample rates, and channel configurations for post-analysis.
    • Data Analysis and Visualization: The software offers tools for analyzing acquired data, performing mathematical calculations, generating plots, graphs, histograms, and exporting data in various formats for further analysis in external software tools or systems.
  5. Integration with Control Systems and External Devices:
    • Integration with PLCs, SCADA systems, industrial controllers, and automation software for process monitoring, control, and data logging.
    • Communication interfaces such as Ethernet, USB, RS-232, RS-485, CAN bus, or wireless protocols for connecting to external devices, networks, or the Internet.
Overall, Data Acquisition Systems play a crucial role in scientific research, engineering experimentation, industrial automation, quality control, environmental monitoring, and many other applications requiring accurate and reliable measurement and analysis of physical parameters or signals.
