Robot & Cobot Forum
676
Aug 26, 2024 6:16 am
The KSS11012 error in a KUKA robot indicates a mismatch between the configured device and the actual device present in slot 1, subslot 1 of the KRC controller. This discrepancy can prevent the robot from functioning correctly.
Common Causes of KSS11012 Error
- Incorrect Device Configuration: The KSS controller may have incorrect information about the device installed in slot 1, subslot 1.
- Hardware Issues: There might be a problem with the device itself, such as a faulty connection or power supply issue.
- Software Glitches: Software errors or conflicts can cause the KSS controller to misidentify the device.
Troubleshooting Steps
- Verify Device Configuration: Check the KSS controller's configuration to ensure that the device type and configuration match the actual device installed in slot 1, subslot 1.
- Inspect Hardware: Ensure that the device is securely connected to the KRC controller and that there are no loose connections or damaged cables.
- Try a Different Slot: If possible, try moving the device to a different slot on the KRC controller to see if the error persists.
