Schneider Drives
439
Jul 20, 2024 10:06 am
Cause : DC Bus ripple error comes when persistent ripple detected on the DC bus or DC bus capacitors damaged. This means the voltage on the drive's DC bus is fluctuating excessively.
"DCRE" in Schneider Electric drive indicates a "DC Bus Ripple Error". This fault signifies that the voltage on the drive's internal DC bus is fluctuating more than the acceptable limit.
- Turn off the device and then turn on again.
- Verify the correct behavior of the input filter.
- Verify the Supply Mains wirings.
- Verify the internal connections.
