Schneider Drives
375
Jul 19, 2024 11:58 am
Cause : Drive mismatch comes when drive type (brand) does not match display terminal type (brand). A "drive mismatch" typically refers to a situation where a component (like a motor, hard drive, or other device) is not compatible with the system or another component it's intended to work with.
"dEU.E" fault in Schneider drive indicate "Drive mismatch error". This means a component or system is not compatible with another.
- Replace the incompatible component.
- Update drivers or firmware.
- Modify system settings.
