F016 Main overvoltage fault in Schneider drive
Cause : Main overvoltage comes when the input voltage to the drive has exceeded the allowable limits. This fault comes due to the line voltage too high.
"F016" fault in Schneider drive indicate "Main Overvoltage" condition. This means the input voltage to the drive has exceeded the allowable limits.
  1. Check Line Voltage: Verify that the input voltage to the drive is within the specified range.
  2. Check Drive Environment: Ensure the drive is installed in a stable electrical environment, away from potential voltage fluctuations.
