Schneider Drives
229
Jul 19, 2024 12:51 pm
Cause : Load short circuit comes when the drive has detected a short circuit on the output side, potentially damaging the drive if not addressed promptly. This fault caused by a short circuit within the motor windings.
"F021" fault in Schneider drive indicate "Load short circuit condition". This means the drive has detected a short circuit on the output side, likely between the drive and the motor.
- Check Motor Windings: Use a motor insulation resistance tester (megger) to check the motor windings for short circuits.
- Inspect Motor Cable: Examine the motor cable for any visible damage, cuts, or signs of overheating.
- Verify External Load: Ensure there are no short circuits in the equipment connected to the motor.
