Schneider Drives
631
Jul 19, 2024 12:10 pm
Cause : Undervoltage comes when the input voltage to the drive has dropped below the allowable limits. This fault comes due to line supply too low or transient voltage dip.
"F030" fault in Schneider drive indicate "undervoltage condition". This means that the input voltage to the drive has dropped below the allowable minimum level.
- Check Line Voltage: Verify that the input voltage to the drive is within the specified range.
- Inspect Power Wiring: Check the power wiring for any resistance or connections that might cause a voltage drop.
