Schneider Drives
255
Jul 20, 2024 10:52 am
The message "F2A" Motor frequency high threshold 2 reached indicates a fault condition in Schneider drive related to the motor's operating speed exceeding a pre-defined limit.
The F2A Motor frequency high threshold 2 reached warning on a Schneider drive indicates that the motor frequency has exceeded a second, higher predefined threshold limit set in the drive's parameters.
- This threshold is typically set to alert for more critical conditions compared to the first high threshold.
- Verify the frequency parameters set in the drive, including maximum frequency limits and scaling.
- Ensure that the motor specifications match the drive settings, particularly the rated frequency and speed.
- Verify that control signals to the drive are stable and within expected ranges. Erratic control signals can cause frequency fluctuations.
