FWER Firmware Update fault in Schneider drive
Cause : Firmware Update error comes when firmware update function has detected an error. This detected error is cleared as soon as its cause has been removed.
The "FWER" Firmware Update fault in Schneider drive indicates an issue encountered during the firmware update process. This fault can prevent the drive from functioning correctly if the firmware update is incomplete or corrupted.
Steps to Address "FWER Firmware Update Fault":
  1. Immediate Actions:
    • Stop Operation: If the drive is running, stop it to prevent any potential damage or unsafe conditions.
    • Reset Fault: Attempt to reset the fault using the drive's control panel or through the connected control system. This may clear temporary issues.
  2. Verify Firmware Update File:
    • File Integrity: Ensure the firmware update file is not corrupted. Download the firmware file again from the official Schneider Electric website if necessary.
    • Compatibility: Check that the firmware file is compatible with the model and version of your ATV610 drive.
  3. Check Update Procedure:
    • Update Method: Follow the recommended procedure for updating the firmware as outlined in the drive's user manual or provided by Schneider Electric. Ensure all steps are performed correctly.
    • Interruption: Ensure the update process is not interrupted (e.g., by power loss or communication failure). If an interruption occurred, restart the update process.
  4. Use Correct Software Tools:
    • Programming Software: Use the correct and latest version of the software tool provided by Schneider Electric for updating the firmware (e.g., SoMove or other recommended tools).
    • Connection Method: Verify that the connection method (USB, Ethernet, etc.) used for the firmware update is functioning correctly.
  5. Inspect Drive Hardware:
    • Connections: Ensure all physical connections to the drive (communication cables, power supply) are secure and functioning.
    • Memory: Verify that the drive's memory is not faulty and can handle the firmware update. This might require technical support.
  6. Retry Firmware Update:
    • Re-attempt Update: If the initial firmware update failed, retry the process with a verified firmware file and following the correct procedure.
    • Restore Previous Firmware: If possible, revert to the previous firmware version to restore the drive's functionality before attempting the update again.
