OPF2 Output phase loss fault in Schneider drive
Cause : Output phase loss comes when the drive has detected a loss of current on all three output phases. The fault could be caused by wiring problems, a blown fuse, or internal drive failures.
"OPF2" Output Phase Loss Fault in a Schneider drive indicates that one or more of the output phases are missing or have a significant imbalance. This means the drive has detected a loss of all three phase currents to the motor.
Follow These Steps to Correct an OPF2 Output Phase Loss Fault:
  1. Immediate Actions:
    • Stop Operation: If the drive is running, stop it immediately to prevent any potential damage to the motor or drive.
    • Reset Error: Attempt to reset the error using the drive’s control panel. This may clear temporary issues.
  2. Inspect Wiring and Connections:
    • Output Wiring: Check the wiring from the drive to the motor for any loose or disconnected wires. Ensure all connections are secure and properly terminated.
    • Continuity Check: Use a multimeter to check for continuity in the output wires. Ensure there are no breaks or disconnections.
  3. Check Motor Connections:
    • Motor Terminals: Inspect the motor terminals for loose or corroded connections. Tighten any loose connections and clean any corrosion.
    • Internal Motor Wiring: If possible, check the internal wiring of the motor for any issues that might cause a phase loss.
  4. Inspect Fuses and Circuit Breakers:
    • Fuses: Check any fuses in the drive's output circuit. Replace any blown fuses with ones of the correct rating.
    • Circuit Breakers: Ensure that any circuit breakers are in good condition and have not tripped.
  5. Verify Parameter Settings:
    • Phase Loss Detection: Ensure that the phase loss detection settings in the drive are configured correctly. Adjust the sensitivity if necessary.
    • Current Limits: Verify that the current limit settings are appropriate for the motor and application.
  6. Check for Internal Drive Issues:
    • Drive Components: Inspect the drive’s internal components, such as output transistors and capacitors, for any signs of damage or failure.
    • Diagnostic Tools: Use diagnostic tools or software provided by Schneider Electric to perform a thorough check of the drive’s internal systems.
