The message "PFES" Position following warning in Schneider Electric drive indicates a potential issue with the drive's ability to precisely follow the programmed position reference for a motor. While it's not necessarily a critical fault causing an immediate shutdown, it's a warning that shouldn't be ignored.
"PFES" "Position following warning" on a Schneider drive indicates that there is an issue with the position feedback system, typically used in applications where precise motor positioning is critical.
- This warning suggests that the drive is unable to correctly follow the commanded position, which can be due to several factors such as misalignment, sensor issues, or incorrect parameter settings.
- Check the condition and alignment of position feedback sensors (e.g., encoders, resolvers).
- Ensure all connections between the position feedback devices and the drive are secure and free from damage or corrosion.
- Verify that the parameters related to position control are correctly configured. This includes settings for feedback devices, control loop parameters, and position limits.
