schneider drive fault codes nst
schneider drive fault codes nst indicates the drive is in freewheel stop mode. This means NST is not a fault but rather a status indicating the drive is in a freewheel stop condition.
To troubleshoot the NST error code, you can try these steps:
  1. Check the freewheel stop assignment.
  2. Check the state of any digital inputs.
  3. Cycle drive power to clear it.
  4. Check if a run command is present when power is applied to the drive.
  5. Check if drive is in a Network setting and the parameter Control Mode [CHCF] is set to Separate or Not Separate.
  6. Check 4-20mA Loss setting and see if it's set to freewheel stop.
