The message "AFFL" in Schneider Electric ATV610 drive indicates a potential issue with communication between the drive and a fieldbus control system. This means an automatic fallback behavior activated after a fieldbus communication interruption.
The "AFFL Automatic fallback behavior activated after a fieldbus communication interruption" warning on a Schneider ATV610 drive indicates that the drive has detected a communication loss with the fieldbus network and has switched to a fallback mode to maintain operation.
- This behavior is designed to ensure that the drive continues to operate safely even when communication with the control system is interrupted.
- nsure the drive is operating safely in its fallback mode. Observe any changes in performance or behavior.
- If the issue appears to be transient, reset the warning to see if normal communication is restored.
- Check all fieldbus cables and connections for signs of damage, wear, or loose connections.
