1,263
Jul 23, 2024 6:47 am
Cause: Brake Control comes when an issue with the drive's brake control system, preventing it from operating correctly. The drive might not be able to achieve the required current to release the brake. This could be due to incorrect IBR parameter settings, motor issues, or power supply problems.
"bLF" fault in Schneider ATV950 drive indicate "Brake Control" error. This means an issue with the drive's brake control system.
Common Causes of bLF Fault:
- Brake Release Current (IBR) Mismatch: This is a common culprit. The IBR parameter, which defines the current required to release the brake, might be incorrectly set.
- Motor Fluxing Issues: If the motor doesn't flux correctly, the drive might not be able to release the brake.
- Brake Hardware Issues: Problems with the brake itself, such as mechanical failures or electrical issues, can cause the fault.
- Drive Parameter Misconfiguration: Incorrect settings of other brake-related parameters can contribute to the fault.
- Sensor Issues: Issues with motor current sensors or other feedback devices can affect brake control.
Follow theses steps to correct the fault:
- Inspect Brake Hardware: Examine the brake for any signs of damage, wear, or malfunction.
- Review Drive Parameters: Check other brake-related parameters such as brake release time, brake current, and brake deceleration.
- Verify Sensor Function: Ensure that current sensors and other feedback devices are functioning correctly.
- Check Drive Connections: Verify all connections related to the brake and motor.
