318
Jul 23, 2024 6:49 am
Cause: Brake Resistor ovid comes when the brake resistor is experiencing excessive current, leading to overheating and potential damage. A resistor with an insufficient power rating can lead to overheating.
"bOF" fault in Schneider ATV950 drive indicate "Brake Resistor ovid" error. This means the braking resistor is experiencing an overcurrent condition.
Here are steps to troubleshoot and resolve the bOF
fault:
1. Inspect the Braking Resistor:
- Physical Condition: Check the braking resistor for any signs of damage, wear, or overheating.
- Resistor Rating: Ensure that the braking resistor is correctly rated for the drive and application. An undersized resistor can cause overcurrent faults.
2. Verify Electrical Connections:
- Wiring Integrity: Inspect all wiring between the drive and the braking resistor for any loose connections, breaks, or damage.
- Secure Connections: Ensure that all electrical connections are tight and secure.
3. Check Drive Settings:
- Brake Resistor Parameters: Verify that the drive parameters related to the braking resistor are correctly configured. This includes settings for braking resistor resistance, braking threshold, and braking power.
- Overcurrent Thresholds: Ensure that the overcurrent thresholds are set correctly according to the braking resistor’s specifications.
4. Monitor Braking Operation:
- Braking Events: Monitor the frequency and intensity of braking events. Excessive or frequent braking can lead to overcurrent conditions.
- Brake Resistor Duty Cycle: Ensure that the duty cycle of the braking resistor is within acceptable limits. Continuous heavy braking may exceed the resistor's capacity.
5. Check for System Overloads:
- Load Conditions: Ensure that the load conditions are within the drive’s capacity. Overloaded systems can cause excessive braking and overcurrent faults.
- Deceleration Settings: Verify that the deceleration time settings are appropriate for the application. Too rapid deceleration can cause high braking currents.
