CFA Cabinet Circuit A Error fault in Schneider ATV950 drive
Cause: Cabinet Circuit A Error comes when the monitoring function has detected an error. The digital input assigned to "CabinetCircuit A Assign" CFAA is active for duration longer than "CabinetCircuit A Delay" FdA.
"CFA" fault in Schneider ATV950 drive indicate "Cabinet Circuit A Error". This means a critical issue within the power electronics section.
  1. Identify the cause of detection..
  2. Check the connected device (door switch, thermal switch,…) and its wiring.
