CFI2 Configuration transfer error fault in Schneider ATV610 drive
Cause : Configuration transfer error comes when the configuration transfer to the device was not successful or interrupted or the configuration loaded is not compatible with the device.
The "CFI2" Configuration transfer error fault on a Schneider ATV610 drive indicates that there is an issue during the transfer of configuration data to the drive. This fault typically occurs when the configuration data being sent to the drive is incomplete, corrupted, or incompatible.
  1. Verify the configuration loaded previously.
  2. Load a compatible configuration.
  3. Use PC software commissioning tool to transfer a compatible configuration.
  4. Perform a factory setting.
