433
Jul 15, 2024 5:37 am
Cause : Fieldbus communication interruption comes when the communication between the fieldbus module and the master (PLC) is interrupted.
A "CNF" fault in Schneider Electric ATV610 drive indicate a Communication Network Fault. This means the drive is unable to establish a connection with the network it's supposed to be communicating on.
- Verify the communication settings on the devices (Drive, PLC, switches, repeater...).
- Check for duplicate communication addresses.
- Verify the environment (electromagnetic compatibility).
- Verify the fieldbus wiring (continuity, cable type, grounding, and shielding).
- Verify the terminating resistor.
- Verify the timeout setting.
- Replace the option module.
