F006 Current measurement circuit fault in Schneider ATV310 drive
Cause : Current measurement circuit comes when current measurement is not correct due to hardware circuit fault. This typically occurs when there's an issue with the hardware responsible for measuring the motor current.
"F006" fault in Schneider ATV310 drive indicate current measurement circuit issue. This means there's an issue with the hardware or software responsible for measuring the current flowing through the drive.
  1. Check Current Sensors: Visually inspect the current sensors for any signs of damage or loose connections.
  2. Verify Load Conditions: Ensure the connected load is within the drive's rated capacity and that there are no abnormal current spikes.
